or in reality what i need help with is the edges, i can see the underbase white on the edges on the print… how do i change the settings and where riin? betterprint?
Hopefully the @admin can help with your problem
I am having issues getting the better print software to come up properly. It is leaving question marks everywhere. I have been fighting this thing for 4 days. SOmeone out there has to know what to do.
Hellooo, maybe try setting the two parameters to 1 1, 2 2, or -1-1, -2-2, and print them separately. Then you can check if the white edge looks better.
Hi, not sure if you’ve already emailed support@loklik.com. If not, you could reach out to them too, they can help with this.
Did you find out the issue with the question marks? I am having the same problem.
Alot of people resolved the question mark issue by changing the language. This video shows you how. Please let us know if this works for you.
