Yes po lalo pag di nakakabit yung tool caddy sa side. Mas payat pati
I tried to make a sticker sheet using uploaded PNG files. I grouped the images on the page (as there is no Attach function like Cricut Design Space) and clicked Make.
I got the message that the selected image has no vector outline so cannot be made.
What am I missing?
When I try using SVG files, I am unable to flatten the images which results in cutting within the images and not around the entire image.
When you uploaded the image did you select print and cut as the function. You can look at my tutorial, it may help you find what you were missing to do.
How to make Sublimation Stickers - Tutorial - LOKLiK Community
I didn’t realize that I needed to switch between Design and Layers to select the cutting options. The software isn’t that complicated but it isn’t intuitive so I’m still trying to figure out how to do things.
Thanks for responding.
They only just changed the way you upload your image in the latest update, so everyone is getting used to it. On a side note, that panel changes for your text options as well. To change the font and size etc. So just keep that in mind too.
Thanks for that.
Hello crafters! I am a newbie crafter and I am so happy about the print and cut function😍 I have 120pcs orders money envelops . I dont have an idea how to share photos here. but,The best method that works for me is to calibrate the machine with the material that I will be using to my project. So far so good. Thankyou for sharing your tips and tricks!
Thanks for sharing this method ![]()
