Materials default parameters
Hi, can the material cutting parameters be reset to default? I can’t find any info about this in the software
best regards
Rune
Let’s ask the @admins. I’m not sure if this can be done
I would like to know also
Hi @Rune! The material cutting parameters are always set to default unless you personalize them. Even then, it´s only for that task, next time they will be default again.
The default parameter you can really modify the default is cutting calibration:
and that can be reset to default:
