necesito ayuda para saber si el lapiz optico puede funcionar en la maquina loklik_crafter , porfavor ayuda
hello and welcome to the community @flor_pompa. do you mean using a stylus for embossing with the Loklik Crafter?
If so, the Crafter is good for cutting and basic scoring, it doesn’t offer the embossing capabilities found in the iCraft. ![]()
Welcome @flor_pompa ! I have the Crafter and I use a dry bic cristal pen to score using the pen function and correcting the 1px offset to the left (move the scoring lines 1px to the right).
I don’t have the scoring tool, but yes, I’ve seen it fitting in the pen housing.
The pen in the Crafter is the same that in the iCraft, the scoring tool goes into the iCraft housing and Crafter’s Pen housing, so it is all the same diameter. I think that the blades’ housings don’t fit in the different models, but it seems the scoring tool do fits in both pen housings.
I’ve made some engraving tests with my scoring tool (bic pen) and it works pretty well. I haven’t tried to emboss foil, but I think it is very possible, I don’t see any reason why not.
The iCraft have some improvements from the Crafter (thicker materials, higher cutting force, more ready to go gadgets-functions). But if you have the Crafter, you can somehow work around any iCraft task.
I hope this helps.
Interesante! ![]()
it’s a good idea with de stylus pen!
Very Welcome @flor_pompa Let us now of you could! ![]()
welcome here, and go on
Feel welcome yourself @pappu_pelu !!
Hi and welcome to the community @pappu_pelu!
We are excited to see you here! If you have questions, feel free to ask under General Section. But for the meantime, you can navigate all the tabs here to be familiarized specially at the Inspiration and Tutorial Sections.
@redhada and @InkiteeWorkshop, Great job on responding to this inquiry! Just woke up here in my location. ![]()
Welcome!!!
Yeah!
There are so many creative ideas!
very early!
