Is there a way to change the opacity of a layer that I used for a fill layer? I am trying to make it so you can see the background through the layer, but I cannot find the option at all. I have clicked on every single button. Also, is there a way to center the image and your text? I can’t locate that option either ![]()
So the opacity thing, I don’t believe there is an option to do this at this stage. To center 2 images or a text layer and an image. Select both and then up the top where it says align you can center it there. If you would like to just center your text you can select text and then under the text options on the top bar you can select align there.
I don’t believe there is at the moment because I tried to do this with one of my projects and couldn’t find a way of doing it.
Have you tried changing the fill setting to contour? This then just shows the outline of each layer.
One thing I can suggest to you, which I’ve done in the past is get another heart and place it on top of The pink heart select both the new heart shape and the Pink one and slice the image, Don’t let the sliced image and then change the colour to pink that way you’re left with a Pink heart.
And if you would like it to look a little bit similar with the border then I suggest you duplicate the heart or set offset .
