hi everyone ,im sorry if i cant post here but i didnt no where else to post something ,Anyway im needing some help if anyone can tell me ,how do i ungroup a layered pic, like you can in other design places, also i cant contour ,all i get is picture turns to lines but cant click on them to remove ,thankyou ,and hoping someone can help …
Hello! First of all, the Loklik Community is the perfect place to ask your questions and concerns—fellow crafters will be happy to help you! Second, could you please share a photo of what’s happening in your work area on Ideastudio? That way, we can better understand your concern and assist you more effectively.
If it is your uploaded picture as png you can’t do anything with it YET.
If it is from Ideastudio you can click the right button of your mouse and you’ll have ungroup option at the bottom.
Or you have also the option from the top panel combine and then split.
At the moment you can only ungroup svg files, uploaded or in the LOKLiK Idea Studio Library.
Contour doesn’t work the way it does in cricut design space. Contour gives you an outlined picture. I normally use a shape and slice away what I don’t want in the design.
