Offline or online?
Still trying to find out if you have to be online or offline to get the icraft to work right ? I really need to be offline when I’m on the road and making a safety sign , and I can’t get online. most of my work is small sign making . I though it was a software malfunction ?
Can you explain a bit more about the project you want to do offline? If you want to upload a design you can and then cut it out offline.
I think it can work offline. You don’t need an internet connection to work with the iCraft. I hope i get what you are trying to ask here. :smiling_face:
It’s a sign, just TEXT. when i go to make it say’s I’m off network ( offline ) to be clear. I bought a Brother printer scanner , DO i print it then put it in the Loklik icraft to cut ?
If you are just doing text that should work offline. Are you signed into your account in loklik still? If you are sign out, go back to canvas, type your text then press make. Connect machine via Bluetooth or USB and choose operation and material and press add to task. Open task list load mat and press start. I can do a little video if you want of my offline process. Maybe you could follow it then?
Also have you updated your software and firmware to the latest versions?
