I have questions, haha. Those of you in the United States, how do you calibrate the machine because it only lets you use A4 paper and here it is very difficult for me to find that size of paper?
Have you tried letter size? I think you can also use that just dont select the letter size in the printer choices, still use a4 as paper size but feed printer with letter sized paper
I have that same problem. Have not figured out what to do yet. I hope you find a solution
I have completed a test on how the A4 paper and the US letter paper works if your using the LOKLiK iCraft and callibrating for Print then Cut. (i used 2 diferent printers)
Test 1: If your printer is an A4 printer, use A4 paper and callibrate following the directions.
Test 2: If your using a US letter printer, use letter settings as you normally would for the paper size, following the directions.
NOTE 1: if you are doing a print then cut callibration on a US letter printer and paper size, it makes no diference if you change your print settings to A4, it’s not necessary.
NOTE 2: what does happen if you use a letter paper size to print before you do the callibration cut? the only noticable diference is that the letter B does not print on the bottom as it does on A4 paper, just hand write it on if you want.
NOTE 3: I did not continue on with the callibration using the letter size print to cut callibration process, because i completed the callibrated on my A4 test and did not need to calibrate a 2nd time.
Yes, and still not cutting good
I see a video on YouTube and I fixed ![]()
What did you to do to fix the cutting?
Thank you I will try and see if this works for me!
that’s great! which video did you follow Yirda?
I see a video on youtube,the person name is (neverdenyme) video tottle(how to calibrate the loklik for print & cut)
The person name is (neverdenyme) video tottle(how to calibrate the loklik for print & cut)
Thanks Yirda!
Me Excited to have one .
@timmytation she teach me how to get the right cutting ![]()
Hahaha kahit banned ni meta pede nmn pla dito ![]()
maam speaking in english ![]()
Hangang kelan ba yan baka maubusan kna ng dugo
maam chatgpt is the answer hahahaa
Sir, pwdi po ba paturo on how the calibration work? Litong. Lito napo ako ![]()
