Maybe try downgrading to v06 and see what happens
Hello again, dear cutting specialists
There has been a small breakthrough in the matter.
As I wrote earlier, I have tried many things.
I have discovered that there are many important things:
Both Icraft and Loklik Idea Studio must be updated.
You must print in A4 with 100% fit.
The mat must be clean and flat.
The material must be placed precisely on the mat and scraped firmly without wrinkles or bubbles.
There must be reasonable lighting conditions.
I have managed all of this with varying degrees of success (mostly failure).
But now I am actually close to reaching my goal.
What timmytation wrote about the gray rubber bands is what has helped the most.
After I fixed them, I can scan many times in a row without any problems.
If it still fails, it helps to turn off Icraft and reconnect.
Right now, it looks like I’ve found the solution.
This was a long post, but thank you all for your help.
I was about to tear my hair out over the weekend.
Best regards from Jan
Translated with DeepL (https://dee.pl/app)
Congratulations ![]()
Yay, so happy you got it working. Great tip from @timmytation ![]()
It was actually from the article of the admins ![]()
