Project | Custom Hunting Shirt:
Custom Hunting Shirt: A Blend of AI Art & Handmade Craft
This project started with a cartoon portrait generated in ChatGPT. From there, I took the artwork into Canva to add his name The Death Doctor and his mantra Keep Watching. Once the design was finalized, I printed it using my HTVRONT D1 DTF printer, cured it in the oven, and pressed it at 330°F for 15 minutes with 90 lbs of pressure on my Auto Heat Press 2.
The shirt is 100% polyester, and the print came out flawless—smooth, vibrant, and durable.
My only hiccup was placement: I wanted his name floating above his hat, but the hat’s size tucked it inside. Even so, the final piece was a hit. His reaction made every step worth it.
core-cipher
Congratulations, Summoner! You’ve summoned Rune [H]!
