Project | SERIAL CRAFTER BLING TEMPLATE
htvrontmysterycube MY LOVE FOR RHINESTONES EXPRESSING MY LOVE FOR CRAFTING!!
I WAS ABLE TO USE IDEASTUDIO AND MY LOKLIK CRAFTER GEN1 TO CREATE THIS BEAUTIFUL RHINESTONE TEMPLATE AND CUT IT OUT USING THE CRAFTER GEN1. I USED THE CARDSTOCK 300G SETTING RAISING THE PRESSURE TO 7, SPEED I LEFT AS IS, AND ONE PASS.
RHINESTON FLOCK I PLACED DIRECTLY TO THE MAKE WITHOUT THE CARRIER . THAT WAY YOUR ABLE TO PEEL IT OFF AND IT WILL LEAVE ALL THE CUT OUT DOTS ON THE MAT . PEEL OFF SLOWLY. LIGHT GRIP MAT BRUSH IN STONES, PICK UP WITH HEAT TRANSFER TAPE, USED AUTO 2 PRESS TO PRESS ONTO THE SHIRT. 340 DEGREES F FOR 20 SEC 150 PRESSURE.
Wow, that is so cool, the rhinestones and the idea to make the template :clap:t2:
Please @amber_curtis lower the letter case, it is yet difficult to non English speakers to understand somethings, it took me a while to unravel your message. Thank you!
Congratulations, Summoner! You’ve summoned Rune [P]! :partying_face:
Does the all caps not translate properly then? I have high liter some non English messages and clicked to translate and was not sure how it worked the other way around.
Oh no, I’m not talking about translator, I don´t use one, I read directly. CAPS are hard to read, as it is well known, more if you’re reading in another language. It’s just that.
Is there a translate button??
In web browser when I highlight it one of the options has been to translate it. I was going to copy a post to translate it to see if I could help and saw it as a option.
Oooh I love it! I need a shirt like this
I’ve seen this design and totally want to make it. Love it a lot. Although I probably would have used a different rhinestone for the crafter word as its hard to see in the picture. It probably looks better in real life though.
Yes it looks clear in person but I seen how it blended in the picture. And tried to upload another with less lighting so it was more clear. :rofl: but it was a fast idea to attempt rhinestone template in ideastudio and have my loklik crafter cut it because I’ve always just used others software and cutter for my rhinestones and last night I got curious to see how well it would work in loklik. I was so excited to learn how much BETTER the results was vs in other brand machines! The loklik cut much better with one single pass/cut and not two like u usually do or is recommended in others! I will be using loklik now for rhinestone templates!
@BellethehowtoGuru
Oh wow thats really good to know. What flock do you use? I just bought some myself as I love the bling bling too hahaha :smiling_face_with_three_hearts:
This flock is from the TRW @BellethehowtoGuru
