Project | Violet Nebula Pulse Mixed Media Wall Art
“Violet Nebula Pulse” is a mixed‑media wall art panel built around bold color, clean lines, and a soft cosmic theme. A violet EVA foam heart sits at the center of a holographic orbit ring, set against a black glitter cardstock background that gives the piece a subtle star‑scattered shimmer. Layered vinyl accents add movement and light, creating a simple but striking design that feels both modern and celestial.
Materials Used:
  • HTVRONT Black glitter cardstock (background)
  • EVA craft foam (2 mm) for the raised heart
  • HTVRONT Holographic adhesive vinyl (orbit ring + stars)
  • Loklik Deep‑Point Blade (for cutting the EVA craft foam)
  • Glue stick (to adhere the foam heart)
  • Hanging tab for hanging
Difficulty Level: Beginner–Intermediate
The cuts are simple, but the clean layering and alignment require a bit of precision. The EVA foam requires use of the Loklik deep-point blade, which is not to be mistaken with the standard deep-cut blade. Great for crafters who want a bold, dimensional look without complicated assembly.
