They (Icraft) seem to be not available anywhere ![]()
also, are the blade holders all different or can a put a deep blade into a foil holder, etc??
thank you
thank you
Hello @preferredimage. Welcome to the community. We’re happy you’re here.
The deep point blades and housing seem to be out of stock, still. I’ve also been waiting for them to get more. Hopefully, they will restock soon.
Yes, the blade housings are all different. No, you can’t put the deep point blade into the foil tool housing. You need the deep point blade and the deep point blade housing, as the housing is made specifically for cutting thicker materials. Therefore, it’s built with a stronger housing to withstand the toughness of the materials. The foil and fine point housings are too weak to cut thick materials like chipboard.
Hello @preferredimage welcome to the community, where abouts are you from? the LOKLiK Cutting Machine 2.0 is available online in USA and Australia, i didnt see it in Canada or UK?
The deep point blade has it’s own housing and is diferent to the foil holder, as is the fine point blade has it’s own housing as well.
I thought they were looking for the iCraft machine, at first, too, but they’re searching for the deep point blade & housing for the iCraft. They’re sold out on the website and at Amazon.
I have emailed Loklik Support and asked them when they’ll be restocking the deep point blade housing. I’ll let you know when I get an answer.
thank you sooooo much!!!
You’re very welcome! ![]()
Hello, @preferredimage, I received a response. Apparently, it will be available again by mid-March. You can thank @Mark for grabbing the last one. ![]()
I guess, we’ll both have to conjure up a little patience.
I mean #sorrynotsorry, I was quick on the draw and got the last one!! ![]()
I wouldn’t be sorry, either… ![]()
thanks Samantha, I have noticed the blades have always been hard to find/buy? hope they restock soon.
You’re welcome. Yeah, they said they’re restocking now, but they won’t be available until mid-March. ![]()
Hi @preferredimage, it’s available on the Loklik Europe website, I don’t know if it will help you because it depends on where you live.
