Slice feature
Do the loklik crafter have the slice feature?
You can’t slice png images YET on the software zone I’ve made a post about it and hopefully they’ll add the feature to the coming updates /
loklik crafter not reading registration marks
lets get some trouble shooting started, what material did you print on @Ronel_Smart :+1:
Hi @Ronel_Smart, sorry to hear you are having print then cut issues.
Some things to check out
  • Have you updated firmware and software?
  • Have you done a print then cut calibration using the same material as your project?
  • Try closing the top lid if your room is very bright, if you have a very dark room try turning the light on.
  • Make sure to place the print then cut project in the top left-hand corner of your light blue cutting mat.
Let me know how you go.
Add this:
  • Check if the printed sheet has a good black print of the reading marks:
too dull? trace them over with a black marker.
too shinny? try printing on a non-glossy surface (place masking tape over the area), or place something like masking tape on that area of the already printed sheet and redraw the lines using a black marker and a ruler.
