Sublimatie
Kan je voor sublimatie print de afdrukrand weglaten zodat je A4 kan afdrukken ?
Hi and welcome to the community @kim_andries!
QUESTION IN ENGLISH: Can you remove the print border for sublimation so that you can print on A4?
ANSWER: Yes, you can usually adjust the print settings to remove or minimize the border. In your printer’s driver or software, look for options like ‘borderless printing’ or ‘fit to page.’ Keep in mind that not all sublimation printers support true borderless A4 printing, so it depends on your specific model. If your printer doesn’t allow it, you may need to trim the edges after printing.
Could you let us know which program you’re using to print your sublimation designs? That way we can provide more tailored assistance.
When you select how you want it don’t don’t select print and cut and just print it if that’s the border your talking about make sure it’s in the paper size have it moved over to left side and hit print you should see preview and make sure paper size is selected right to print on the size you want with no cut boarders.
the loklik icraft with the epson sc f100
