System fonts on mac
Hi everyone!
I’m new to the LOKLiK world and I’m struggling soooo much.
Is there a way to have the downloaded fonts work in IdeaStudio?
Thanks for your help!
Are you using phone or desktop? If you are using iPhone there is a bug where system fonts aren’t showing up. On desktop you can click on font and then go to the tab that says system fonts. This is the fonts on your computer. Also you need to make sure that you have downloaded the correct font type as loklik only sees true type font files.
I have a video explaining this, I am using Windows but you should be able to follow along. https://youtu.be/DvcMuqemVeA?si=KsU1gGmK7cE7jcxt
Thank you, you were right!
TTF works just fine!
You can try checking System Fonts, scroll all the way down
