Trouble with Magenta
I have an HTVRont D2 DTF printer, that I just unboxed last night. I am having trouble with magenta.
Blue prints correctly, Black prints correctly, Red prints orange, and Magenta prints lavender
I have completed multiple nozzle checks show magenta weaker than the other channels - it’s light colored and dashed throughout
Head cleaning didn’t improve it
Printing additional pages didn’t improve it
Any other suggestions? I’m a new DTF printer owner, so please be kind. I have building/buying gang sheets for quite some time, and decided to take the leap to get my own printer.
Thank you in advance!
Leslie
Hi @leslie3583, welcome to the community. Congratulations on your new printer.
If your D2 printer starts printing lavender instead of magenta, it usually means the magenta ink isn’t coming out at full strength. A few things can cause that, like white ink getting into the magenta line, leftover cleaning solution still in the magenta channel, a partial clog, air in the line, or magenta ink that wasn’t shaken and settled over time. Any of those can make the magenta look pale or lavender. You can try purging the magenta channel a few times to get the color fully saturated again, check the line for air or contamination, and make sure the magenta ink is shaken and flowing well. These steps often help bring the magenta back to normal, but results can vary depending on what’s going on inside the printer.
Where can I find instructions to try the things you mentioned?
Ok, now that I’m rested, let’s address the full specs again, and I’ll try to give you instructions on how to do these things. Since the D2 is very new, there’s not a lot of documentation on how to do these things. So I’m going by how it is done with other DTF printers, as I don’t have the D2.
Since your D2 is printing magenta as lavender and red as orange, that means both colors are not getting full magenta output. Red is made from magenta + yellow, so if magenta is weak, red will shift toward orange. The nozzle check showing a light, broken magenta pattern confirms the magenta channel isn’t getting full ink flow. A head cleaning alone doesn’t always fix this on the D2, especially right out of the box. Here are the steps you can try next:
1. Run another head cleaning.
Sometimes the first cleaning doesn’t move enough ink through a brand‑new line. After the cleaning finishes, run a nozzle check to see if the magenta pattern improves at all.
2. Run Ink Charge / Prime if your D2 shows that option.
Some DTF units have “Ink Charge” or “Prime” in the maintenance menu. This pulls ink through the lines more strongly than a normal cleaning and can help clear air or diluted ink in the magenta line.
3. Print several solid magenta blocks.
Open IdeaStudio and create a solid magenta square. Print it a few times in a row. This forces the printer to fire the magenta nozzles continuously, which helps pull fresh ink through the channel and strengthen the color.
4. Shake the magenta ink bottle well.
DTF pigment settles fast, especially magenta. If the bottle wasn’t shaken before filling, the pigment can be weak and cause pale or lavender output. Shake it for at least 30 seconds, let the bubbles settle, then run another cleaning or print more solid blocks so the freshly mixed ink reaches the printhead.
5. Check the magenta ink line.
Look at the magenta line and see if there are bubbles, gaps, or cloudy/milky ink. Air pockets or diluted ink can cause weak magenta. Running a cleaning, ink charge, or printing solid blocks can help pull the ink through and clear the line.
6. Run a nozzle check after each step.
If the magenta pattern starts filling in more, you’re making progress. Once magenta prints at full strength, your red will correct itself too.
Since the printer is brand new, this is usually just air in the line or pigment separation from shipping. It often clears after a combination of priming, cleaning, and printing solid color blocks.
Thank you for your help, unfortunately none of these have solved my problem, and now, yellow is blending into white. I’m going to reach out to HTVRont to see if they can help. I hope I just didn’t buy a very expensive paperweight.
You’re welcome. I’m sorry none of it worked. The good news is, it’s under warranty, so they will either have to fix it or replace it if it isn’t fixable on the user’s end.
