Hello, I tried many ways but couldn’t find the right one. In the example below, there is a duck. Let’s say I need to cut the duck in my example in two different colors. The first is the frame, the second is the inside. When I sent it to the machine to cut, it was cutting both the inside and the outside. I solved this problem by following the explanation below.
https://community.loklik.com/t/contour-to-delete/384/4
However, this time I encountered something else.
When we consider this picture; for example, the outside frame will be black, the inside parts will be yellow. The outside frame cutting is already successful. However, when I want to cut the inside, I reverse the process. In other words, I turn back on the layer hiding action explained in the address above one by one. If I do this, it creates a new duck for me. As if I threw the duck back onto the canvas. Okay, but the duck is not aligned with the previous duck and is not the size I set. Therefore, in this case, the lines will not coincide and there will be a shift in the cut.
How can I solve this problem. Can anyone with experience help?
