📘 Understanding GSM in Cardstock
GSM (Grams per Square Meter) is the universal measurement used to describe the weight, density, and overall sturdiness of cardstock. A higher GSM number means the cardstock is thicker, heavier, and more durable, making it ideal for projects that need structure (like business cards or invitations). Lower GSM numbers indicate lighter, more flexible paper—similar to standard printer paper (80–100 GSM).
Higher GSM = thicker, sturdier, more premium
Lower GSM = thinner, lighter, more flexible
:mag: How GSM Works
Definition:
GSM represents the weight in grams of a sheet of paper measuring 1 meter × 1 meter.
Why It’s Universal Unlike “pound” (lb) paper weight—which varies depending on the type of paper being measured—GSM is consistent across all paper types, making it the most reliable way to compare true thickness and quality.
:straight_ruler: Common GSM Ranges for Paper & Cardstock
GSM Range Type Typical Uses
80–100 GSM Standard paper Printer paper, worksheets, inserts
120–170 GSM Light cardstock Flyers, brochures, layering pieces
200–300 GSM Heavy cardstock Greeting cards, invitations, business cards
300+ GSM Extra‑heavy cardstock Premium cards, luxury prints, structural crafts
:star: Why GSM Matters for Cardstock
Durability
Higher GSM cardstock resists bending, creasing, and wear—perfect for items handled often or meant to last.
Feel & Quality
Thicker cardstock has a more professional, premium, and substantial feel, which elevates the final project.
Project Suitability
Choosing the right GSM ensures your cardstock performs well for its intended use—whether that’s crafting, printing, scoring, or structural builds.
:scissors: Additional Cardstock Tips Worth Knowing
Texture Affects Cutting
  • Smooth cardstock cuts cleanest on machines like Loklik
  • Textured cardstock (linen, canvas, glitter) may require more pressure or a different blade.
Core Type Matters
  • Solid‑core cardstock is the same color all the way through—ideal for clean cuts.
  • White‑core cardstock shows white edges when cut or torn, which can be a design choice or a drawback depending on the project.
Coated vs. Uncoated
  • Coated cardstock (glossy, matte, pearl) is great for printing vibrant images.
  • Uncoated cardstock is better for writing, stamping, and crafting.
Machine Compatibility
  • Most cutting machines handle up to ~110 lb / 300 GSM comfortably.
  • Anything thicker may require multiple passes or a specialty blade.
Scoring Is Essential for High GSM
Heavier cardstock cracks when folded unless it’s scored first—especially 250+ GSM.
:blossom: Final Thoughts
Choosing the right GSM isn’t just a technical decision — it’s a creative one. The weight of your cardstock shapes how your project feels, how it holds up over time, and how confidently it represents your vision. Whether you’re crafting keepsakes, designing professional pieces, or building something meant to inspire, understanding GSM gives you the power to choose materials that match your intention.
At the end of the day, the “best” cardstock is the one that supports your story, your style, and your purpose. When you know what each GSM can do, you’re not just picking paper — you’re setting the foundation for a project that feels as good as it looks.
Such helpful information — I always rely on GSM measurements as my guide. Thanks so much for sharing.
You’re very welcome! I know I was confused about lbs and GSM in the beginning, too. I thought others would like to know the difference. @Nancy_Sierchio kind of inspired this post, as she asked earlier where she could go to learn more about cardstock. I thought it’d be a good topic to discuss here. I’m happy you think it’s useful, too. :smiley::+1::heart:
You are the bestest @Samantha_Bryant!!!
Awww! Thank you! I think you’re pretty awesome, too! :heart: Hope this post helps you and anyone else who is interested in cardstock crafts.
Thank you. :brown_heart:
You’re very welcome! :heart:
Hi, thanks for the info! :heart_eyes: :heart_eyes:
Hi! :wave::smiley: You’re most welcome! I’m happy you found it useful. :heart:
