Hey! Iam new. I upload an svg and show what happen .
can someone help, what is the problem?
Hey! I solved it. Thanks
How were you able to solve it? Can you show us the output?
Since IG doesn’t support gradient, the only solution is to convert it to rasterized image with another program and maybe keep the shilouette.
Or print it ouside IS and then print and cut with the already printed sheet.
I thought there are maybe something at the backround that i cant see. so i choose first remove backround with Ai
then print and cut
Ah ok, so it wasn’t a svg but a rasterized image (png, jpg, bmp… no vector). In a vector image, the background would be a layer that you would be able to click and delete.
So you needed to perform just the regular png (o whatever raster) removing background IS function xdd
