Very important message from the manufacturer
For the cutting of the wooden boards:
For now, w**e only tested basswood in 1.5mm thickness, with force 5.5, speed 2 and passes 6; for 1.7mm basswood it cuts very difficult and has some rough edges;
For the metal sheets:
The metal plate is difficult to cut, the tip of the blade is easily to collapse and damage**​
=> This is not advised or even possible
I think in cricut they use a knife blade for thicker and denser materials, not sure if it can be used with loklik.
Thank you for sharing the manufacturer’s recommendations. Following the recommended settings is critical to ensure optimal performance and safety.
