3d Box - which paper is required?
Hello people,
I was wondering what type/kind of paper you need or can all use to make a functional 3D box (from the loklik library).
I had already found Scrapbook/design paper because I couldn’t find it anywhere what type of matriaal is needed for this and don’t want to risk getting things for nothing I wanted to ask anyway.
Photo paper is glossy and there are many thickness you can choose from
Usually thicker paper like cards stock, calling card paper, etc
Yes, card stock is better, I normally tend to go with a cardstock that doesn’t have a white core in it. As these tend to cut a bit messy. I normally use anything over 300 GSM paper weight for boxes.
Anything between 150 and 300 g, depending on how rigid you want it. Lighter won’t be sturdy, and thicker will require some adjustments in the design to account for the material’s thickness, i mean folding allowance, thickness compensation.
you can practice photopaper
If it is a small box or holding a very light item, I uses 65lb cardstock. For larger 3D boxes and for sturdiness I use at least 80lb cardstock.
I’m using photopaper
mi loklik crafter esta cortando fatal
Qué le pasa?
Welcome @salazar_mari . How is your cutter cutting badly. What’s it doing, what have you done to try and fix it?
what paper size can you recommend?
Do you mean paper weight? I normally use cardstock 300gsm or over for these boxes, so it has structure to the box. The paper size will vary depending how big you need your box. I mostly use scrapbook size though 30cm by 30cm
