Come si fanno i biglietti di auguri fronte retro?
This would be tricky. 1st your mat needs to be less sticky so it won’t get ruined. Next would be, to know your peinter well of you will use print and cut.
Fo you have a design in mind?
It would be possible. What do you want on your greeting card? I made this greeting card recently with a greeting on the front and then an insert of a message inside.
Create A Cute Easter Greeting Card Using Your LOKLiK iCraft - Tutorial - LOKLiK Community
