D1 dtf machine ink will not flow from bottles to tubes
my brand new d1 dtf printer ink will not flow from bottles through tubes
Hi Carolan, welcome to the community. The user manual includes the first-time setup steps, including how to get the ink to flow into the tubes. Please check that section. If it still doesn’t work, please contact support@htvront.com for help.
Hi and Welcome to the Community @Carolan_Atkinson! Please read the HTVRONT D1 DTF Printer User Manual as suggested by @OliviaZzz . Hope you get your ink flowing soon. Please keep us updated! :wink:
Hello everyone … finally able to set up my dtf printer and ive hit a road block … only my white ink started to flow…the other colors have not started flowing through the tubes and i have no idea what to do next . I have looked for videos but found none…
Im a newbie when it comes to this software and this printer … so if anyone can please help ill forever be grateful
Hi, Kimberly, I know I sent you a link to one thread in the FB messenger group, but here’s another one you may want to check out for setting up a brand new printer. Hope it helps. Let us know if any of these suggestions worked for you. :heart:
@Kimberly_Leonardo, Congrats on getting your DTF printer set up — that first power‑on is always exciting, even when it throws a curveball. You’re definitely not alone in this, and the good news is that color channels not flowing at first is a pretty common hiccup.
A few things you can try:
:rainbow: 1. Run a couple of head cleanings
Sometimes the color channels just need a little help getting started. Running 2–3 cleanings (with a few minutes between each) can usually pull the ink through.
:test_tube: 2. Check your dampers
Make sure the dampers for CMYK are fully seated and clicked in. If one isn’t sealed properly, that color won’t pull ink.
:arrows_counterclockwise: 3. Gently prime the lines
If your printer has manual priming syringes, you can very gently pull ink through each color line until you see it reach the damper. Don’t force it — just a light pull to get things moving.
:soap: 4. Make sure your ink bottles are vented
If the vents are closed, the printer can’t pull ink. A tiny detail, but it makes a huge difference.
:fire_extinguisher: 5. Check for air gaps
If you see big pockets of air in the CMYK tubes, they may need to be primed or the printer may need a few more cleanings to push the air out.
You’re doing great — DTF has a learning curve, but once you get past these first setup quirks, it gets so much smoother. If you can share which printer model you have, folks can give even more specific steps.
You’ve got this, and we’re happy to help you get up and running.
How do i check the dampers? Are there videos ? When i say im a newbie i mean it lol i dont want to screw anything up
Great question! On the LOKLIK DTF printer, the dampers sit right above the printhead and checking them is mostly a visual inspection to make sure each one is fully seated and has ink flowing into it.
Here’s how you can check them:
:wrench: How to check your dampers
• Open the top cover and look for the small rectangular cartridges sitting on top of the printhead — those are your dampers.
• Each damper should be firmly clicked into place. If one is loose, that color won’t pull ink.
• You should also see ink inside each damper. If one looks empty or has a big air gap, that channel may need priming.
Here’s a link that might help you locate your dampers. :wink:
Hi @Carolan_Atkinson and @Kimberly_Leonardo. Just checking in with you both to see if you got that ink flowing? If you could let us know how you are both going that would be greatly apreciated.
I havent yet…im hoping to try again today…about to drop the kods off at school and then try again
I usually get it flowing by pulling the ink through the dampers :slight_smile: Make sure to clean the syringe before using on each color, or a seperate syringe for each color is great!
I also put pulled ink rightr back into the ink bottle so it is not wasted.
Good luck!
Is there a video of someone doing that…im super scared of messing up the machine …
Hi @Kimberly_Leonardo I can make a video when home Thursday :slight_smile:
Thank you id appreciate it so much …
I am new to this just set up my machine and I’m having the same issue except all colors except yellow are flowing. How were you able to resolve your issue?
Have you tried any of the tips listed above in this thread yet? If you can let us know what you have tried, we can help you better.
In addition, I would also create a support ticket with HTVRont/LOKLiK. That way a professional will be able to help you as well.
