Dashed line
I hope you can help me—I’m feeling a bit frustrated and have a bunch of ruined cardstock. When I create a design and apply a dashed line pattern, the machine makes a full cut instead of a scoring line for folding.
Do you know how I can get it to score instead of cut?
I’m new to using the plotter and I just can’t figure out what’s going wrong.
For folds, I use the scoring pen, but I would also like to be able to use the machine for this purpose.
PLEASE HELP!
Hi @MONICA_DOCENA! I don’t have the iCrafter — I have the Crafter, which doesn’t have a scoring function, so I use a little trick with a scoring tool placed in the pen holder. That’s not really the point here, just to explain that I can’t say exactly how the iCraft handles scoring.
But one thing I’m pretty sure about: the iCraft has only one tool holder, right? So if your machine is cutting instead of scoring, it probably means there’s a blade in the holder instead of a scoring tool. That would explain why it’s cutting — it’s just using the wrong tool. Someone with the iCraft can confirm, but I think it makes sense logically.
I first thought it could be a setting issue, like with my Crafter, but then I realized that on your machine it might be more straightforward — it can’t both cut and score unless you switch the tools manually.
Hope this helps!
Oh — just a quick note: you might want to post questions like this under the Machine, Software, or General sections. This one is for Tutorials, so maybe an @admin can move it for you :blush:
Hi @MONICA_DOCENA, which machine are you using. The LOKLiK crafter or the LOKLiK iCraft? The LOKLiK crafter doesn’t have the ability to score but as @redhada said there are work arounds to do it.
If you have the LOKLiK iCraft there is a scoring stylus that you can buy to put in to the machine where the blade goes when you are ready to score. You can use the scoring line in the pattern section of LOKLiK Idea Studio to create your scoring line within the program. Once your project is ready you can select make, then use the operation score at the top of the make screen instead of cut. Make sure you put the right tool in for what operation you are doing. If you don’t have the stylus, you can adjust your force settings, so the blade only slightly goes into the cardstock and doesn’t cut all the way through. I think I set my force to 3 or 4 to score with the 45 degree blade.
hello @redhada Maybe it’s as you say, I’ll keep trying. Thank you for your response. :smile:
hello @BellethehowtoGuru My machine is the Icraft. I’ll try what you said—these things happen to me because I’m a beginner with a cutting plotter. What you told me is really helpful. Thank you so much for your reply and for taking the time to answer me. :wink:
No worries, I’m glad I could help.
The scoring tool isn’t available in all regions. If you want to use a dashed line as a guide for the folds, try looking for an svg of a dashed line and upload that to idea studio. The dashed line in the shapes tool dispalys as dashed but still cuts as a staright line and not a dashed line. I hope this can be resolved in future updates.
check out these instructions Monica by @skyicreations Scoring Pen - alternate option
Thank you for sharing! @MONICA_DOCENA please feel free to comment and let me know if you have any questions after going thru the tutorial. I have used the work around many times and I love it!!!
Done! :wink: I am double checking and read everything carefully as your new moderator. Also, I added a tag as “icraft” under machine section as identified by the user/member in order to be organized and specific in that way.
Rinsky attack! :smile:
Thank you!
I am finding a lots of it! :rofl: I am enjoying reading all the threads though! And clean afterwards.
It’s great the place is getting more organized. There are more categories to place topics on :smiling_face_with_three_hearts: and sometimes we either forget or unsure where to put them so thanks much for keeping the community “tidy” :star_struck:
Oh, yeah! You bet. I’m on it! And looking forward to get things organized as we dwell onto this place like our second home for Crafters/Creators like us. :blush:
