Die Cut Stickers | Print and Cut
Print and Cut with the Loklik Icraft :smiling_face:
copy_3785404F-9D25-4341-AD32-BD3591D915BE
Materials:
Loklik Icraft
Fine Blade
Glossy Vinyl Sticker
Matte Cold Laminating Film
Light Grip Mat
I layout first my stickers at Canva using A4 size then save as PNG.
File size should be 5mb maximum so IdeaStudio can accept it.
Manually adjust uploaded image to A4 paper fit into the registration marks
Select then Make - Print and Cut.
Print the image. I am using Vinyl Glossy here.
After printing, I added a Matte Photo Top Cold Laminate for protection.
Insert the Mat to the Machine, select Materials - Matte Vinyl 140gsm / Size: A4n
Force - 11
Speed - 5
Pass - 2
Hope this helps.
These are great thank you so much 🩵
So you say it’s easier to make the stickers in Canva and upload it as a one sheet rather than uploading every pic to idea studio!
This is just me. I find it easy doing the layout in Canva rather than doing it in the IS. :smiling_face: Just make sure to change the file size limit to 5000kb so IS can upload it.
I’ll try it thank you :hugs:
Wow! That is a great idea. Does the quality of the image/sticker get very low since there is a file size limit?
I think quality is still good. I chose the biggest size I can get from canva and choose the file size limit of 5000kb.
Hoping to get an icraft as well so I can try this out :smiling_face_with_three_hearts:
Those look so good! Thanks for the great video!
Oh wow, did the perfect stickers? It’s lovely to see you that the printer is working for you on the I Craft, I can’t wait to get mine and try these because stickers are very popular for me. Well done. I want to ask Can you do a full sheet of stickers with the I craft? Is there a lot of paper wasted? I know the software’s don’t allow a full sheet of paper for printing cut.
The registration marks would hinder the full print that’s why i wish the registration marks can be adjusted and placed as far as it can go on the paper sheet like the siser cutting machines. I feel sad when materials are wasted :disappointed_relieved:
I personally think the registration box should be much more finer and pushback so we could get full sheet of Stickers. I waste too much paper.
I think this is the hardest thing to do ( a full sheet) coz for years now Cricut user have been asking for this and till now there is no full page printing :face_with_diagonal_mouth:
I think that is more possible for cutting machines with camera sensors rather than laser sensors like siser and brother. That’s why cricut is also having a hard time with it, it uses the same sensors as loklik I guess :woman_shrugging:
Its definitely possible, I have used almost the entire page to print on Silhouette, just not sure why other brands are restricted.
See on this print/cut, I was able to use all the sheet minus a small border. But I have only been able to do this with Silhouette
Same. I feel sad whenever there is a paper wasted. If only Loklik can do that.
Yes I know that silhouette has this feature and idk why others can’t just do it :face_with_diagonal_mouth::face_with_diagonal_mouth::face_with_diagonal_mouth:
.5mm magnet
I hope this can be fixed in future updates :crossed_fingers::pray:t2:
Can you use this software with a cricut?
