Failing to read the Registration marks
Hi everyone, I need some help with my Loklik Crafter machine. I’m having trouble with the print-and-cut calibration—it keeps failing to read the registration mark. Also, the standard cut function isn’t working properly either. Has anyone experienced this or know how to fix it? I’d really appreciate your help. Thank you so much!
We have a couple of extensive guides on print then cut calibration in the community, but I can’t find them at the moment. I’m sure someone with the right permissions will share a link soon.
In the meantime… could you tell us what issue you’re experiencing with the standard cut? And if you can share a couple of pictures—one of the calibration sheet and another showing the cutting issue—it’ll be much easier for the community to help you out quickly.
Also, is it a calibration problem or a reading registration mark problem? Now that I´m reading you again, it´s not quite clear.
Make sure both firmware and software are up to date
Make sure the room is completely dark it worked with me that way
Or the opposite… not enough light. I just did a print & cut test myself, and of course, the lack of proper lighting drove my Crafter crazy… This is one of those classic P&Cs I leave for the next day, and then it works perfectly. I could add more light, but it’s late over here.
Another thing that can cause issues is when the printing material is either too matte or too shiny. In the first case, you can go over the lines with a pen or marker. In the second, you can stick some tape on the corners so the registration marks get printed on a less shiny surface.
Could you explain what problems you are having with print then cut and standard cut. Giving us more information as what is actually happening would really help us to help you.
My tips is make sure everything is up to date. Firmware and Software
After that do a normal cut calibration and do a test cut to see if it worked. If it was fine complete a print then cut calibration, then test that.
This is a link to the community print then cut help section
I also have issues with the print and cut. I’ve calibrated the heck out of the machine. I’ve made sure my registration marks are on point ( I mean not smudge or covered up with anything) but still end up with the machine not being able to read the lines. I’ve practically given up.
can you confirm if you have these updates correct? :smile:
What kind of paper are you printing on? Besides that, sometimes the reader has a difficult time reading the marks if there’s too much or too little light. If there’s too much, put the lid down and if too little, give the space more light.
Oh, I stay on top of my updates… :wink:
I use a variety of paper and some times the lines are faded which I get it now working, but does it really not work if the lines are too dark?
No, it’s not that. If the lines aren’t dark enough, if they reflect light, or if there’s too much or too little light in the room, the reader might fail or cut inaccurately, not following the cutting lines properly. Otherwise, the result is pixel perfect.
perfect, did you figure it out?
I haven’t had a need to print and cut, but when I do I’ll let you know.
Sorry @Lauriece_Logan-Breen I meant to ask this question to @buena.printandcrafts the original question :upside_down_face:
