iCrafter Print-then-Cut Calibration: What Worked for Me
Hi guys! I recently struggled with calibrating print-then-cut for the iCrafter on V07. I eventually figured it out thanks to Belle’s post Calibrating Print then Cut after V7, so I wanted to share what worked for me.
My Setup:
  • iCraft (V07) + Epson EcoTank + MacBook (macOS Tahoe).
  • Calibration Sheet: I used the new calibration sheet where you can run calibration 3 times on a single piece of paper.
  • Paper: I calibrated on letter size copy paper, but it worked perfectly on A4 laminated sticker sheets afterward.
  • Lighting: My room has a standard mix of natural and artificial light.
My Tips:
  • Check your firmware first! I made the mistake of ignoring the warning text that explicitly says firmware must be V07. I assumed my new machine was up to date, but it was actually on V03—which caused the calibration cuts to go completely wild.
  • Ensuring registration marks are crisp. I found that on inkjet printers, marks can get wavy if the nozzles are clogged or if printing on “Economy” mode. This might lead to errors or inconsistent results.
  • Not obsessing over cut lines on the calibration sheet. Instead of repeating the calibration process over and over until cut lines hit 0 perfectly on all sides, try this: run the calibration once, cut a test project, and then decide if you need to adjust further.
  • Testing with generated contours. In my experience, the cut on generated contours (for raster uploads) tends to be less accurate than on the built-in basic shapes (which are vectors). If your project relies on generated contours, make sure you test with those.
I hope sharing my experience saves you the headache I went through! Feel free to drop a comment below if you have any questions or other discoveries—I’d be happy to help if I can. Happy crafting!
Thank you so much for sharing your experience and what worked well for you. This definitely can help others who may have the same issues you did.
