Making perforated tear strips
Hi, do you have experience making perforated tear strips? Is it necessary to have a perforation blade, and if so, which one is available for Loklik?
I think this can be achieved by mking dashed lines
For the LOKLiK icraft I’m unsure if they do the blade at the moment but no doubt they will bring it out in the future however as Timmy has stated it is possible to do manually by creating – lines within the program.
You can create a dash line so Loklik can read it when cutting.
Or there are manual cutting tools or paper trimmer which offer dashline blade for cutting
I attempted to make perforate lines on a design. I was not able to find the setting or option. I thought of uploading an SVG of a dashed line (the shape was a circle so drawing many lines to create the circle would be difficult). Unfortunately, the SVG import read the file as score marks and does not cut it as dashed lines. My work around for now would be to add small lines to make the dashed line, if it is a straight shape. I ended up using the imported SVG as a cut line using a very low setting so it would not cut all the way thru my paper.
