If you are a new crafter, I hope this post will find you coz I’m going to show you how I make my most sales item
Acrylic sign
Materials
Computer / tablet / mobile
Cutting machine (Loklik icraft)
Software (Loklik idea studio)
Adhesive cutting mat
Permanent adhesive vinyl
Weeding tools
Transfer tape
Acrylic sign
After you upload your design to the idea studio, connect the machine and choose the right settings.
As I showed in the picture above I chose two different kinds of vinyls and luckily I saw the perfect settings for them.
Altough the brand wasn’t Loklik I chose the settings from Loklik brand
settings
For the purple vinyl I chose chrome vinyl
For the pink vinyl I chose holographic glitter vinyl
Now let’s start cutting each vinyl by it’s own because we have two different types.
Now this step is very important when you try new materials after cutting don’t unload the mat and try to weed a small piece to see if it’s cut through, if it’s not then you press the start button again and it will cut one more time.
Luckily the settings were perfect as you see
Now let’s come to the fun part
weeding and applying the vinyl
As you see weeding was very smooth and satisfying
Fix the sign so it doesn’t move and start applying the vinyl
If you follow the steps correctly then your acrylic sign should look like this
And now it’s up to you or the order you can paint the acrylic sign with any acrylic paint, or leave it transparent.
I paint it white and put some flowers.
Finally here’s the final project
I hope you like it and if you have any questions please comment below.
You creator Marin from marinos.creations
