How can you cut only the outline of the image? it only has black color group in the option and cut up to the inside. ![]()
So you only want to cut around the bunny? Did you upload the image?
Have you tried UNITE in combine?
not yet
yes only the outer part. i just got it on the library for testing
You can try the combine then unite. It may turn the bunny black though. If it does you could create an offset and then use that as your cut outline
Try unite as my friends said. And please edit the Category of your post and change it from Tutorial to general ![]()
I am assuming that you used the bunny file as a print-then-cut. If so, you can add an offset of “0” to the most outer layer and only send that offset layer to cut.
