Print then Cut Calibration tutorial LOKLiK IdeaStudio 3.0
:scissors: Print then Cut Calibration Tuorial using the LOKLiK Cutting Machine 2
If you’re diving into the world of LOKLiK Cutting Machine 2 crafting—or you’ve been struggling to get those perfectly aligned Print Then Cut projects—this new tutorial is an absolute gem.
I walk through the entire Print Then Cut calibration process inside LOKLiK IdeaStudio 3.0, breaking it down step‑by‑step so anyone can follow along.
:wrench: What You’ll Learn
  • How to run the Print Then Cut calibration from start to finish
  • What the calibration sheet actually means and how to read it
  • How to interpret your calibration values
  • Tips for testing your calibration and dialing in accuracy
  • How to reset calibration values if things go sideways
  • A full walkthrough of making stickers using your own uploaded images
This is a link to my print then cut test sheet print then cut test sheet I used.
Print Then Cut can be one of the most frustrating parts of any cutting machine workflow—but when it’s dialed in, it unlocks a whole new level of crafting. I hope this tutorial helps others that are having trouble getting this calibrated. Please pop down in the comments with your thoughts or problems. I’ll try to help where I can.
Have a craftastic day :smiley:
I will give this a watch in the morning! :heart: Have a great day! Goodnight! :laughing:
Night, hope you have a good sleep. I’m going to go have some lunch hahaha :rofl:
Had a great sleep, gonna eat me some breakfast and watch your video. :laughing::+1: Hope you enjoyed your lunch. :heart:
Oh, that’s so good to hear you had a great sleep :smiley: Makes the day so much better
Thank you, and, yes, it sure does. :smiley::+1::heart:
I have no likes left for 22hrs so this is my like :heart:
Thank you dear for the wonderful tutorial and all the time (7 hours) you spend ti make it :heart:
Awesome. I will try and watch it the next time I have some down time. Thank you for this.
Yes, this video tried and tested me this week. Thank you @Marino, hopefully others can learn and get theirs calibrated quicker than I did.
You are welcome, hopefully it helps you in your calibration process.
I really need this, especially on days when my machine refuses to cooperate. :laughing::laughing:
Yup, that was yesterday for me. :rofl: But got there in the end
I must make time to watch this, this week-end i havent calibrated using the new system yet bc my machine cuts great atm lol i’m nervous to put it out of wack!
I felt the same way at first, but I managed to get mine cutting properly again. I upgraded my firmware from v7 to v8 before recalibrating, and I definitely recommend running a calibration after updating. My cuts were off until I did. After one calibration, my matte material settings were cutting perfectly. But when I tried using those same settings on glossy material, they didn’t work anymore. I ended up calibrating the glossy material separately, and once I did, it started cutting cleanly again.
thanks Belle, fingers crossed i get a smooth update and cal!
I downgraded from v7 to v6 because v7 and I just couldn’t get along. :sweat_smile:
I used the same materials and calibration settings, but when it came to the moment of truth, the cuts were already off—so I went back to v6.
Hopefully, v8 will finally be the one I can work well with! :laughing:
Hopefully v8 works better for you. I do recommend using the new calibration sheet with the v8 firmware. Just keep in mind you may need to do a couple calibrations to get good cuts.
great!
