Print then Cut Calibration tutorial LOKLiK IdeaStudio 3.0
Also something that worked for me regarding printing and cutting.
Before cutting stickers I always do a test on a rough print on A4 paper. If it doesn’t cut well I do a reset to the print and cut material I want to cut, and then i do the new calibration again from scratch. I check it with a test on a rough print on A4 paper and then if everything is ok i start to cut my stickers . If not a second and a third calibration repeated.
If you plan to use the same materials again, you can set up separate calibrations for each one. Just choose the material you want from the drop‑down menu on the calibration screen.
For example, I have different calibrations saved for my sticker sheets, sticker sheets with laminate, sublimation sheets, cardstock, and glossy sticker sheets. I simply switch to the matching material setting before I cut, and it works perfectly every time.
