Sticky Mat Problem
How can you prevent your papers stick in the mat…I also tried to put the shinny part of the paper facing the mat
Then I used the Light Blue Mat(Light Grip) I scraped some of the adhesive and it works on mirrored cardstock but not on ordinary paper
IMG_20241227_165826_566|500x500
I’m struggling posting Pictures​:sob::sob::sob:
Try dabbing it on a towel or on your clothes to lessen the stickiness before putting in your material
I used baby powder and it works for me :grin:
I tried this ang it was too much for me. It lost all stickiness :rofl:
After you apply wait for a little bit it will moist again but the adhessive will be lessen :grin:
Mine works only on heavy cardstock and I struggle cutting light cardstock
There is all a light tack mat the color blue
For cardstock, you should use the blue colour mat or a light grip mat. With all new mats I always give them a couple hugs on my shirt. You can also use cardboard and place that on your mat a couple times to reduce the stickyness of the mat. Also to help get your paper off the mat you can flip the mat over and start bending the mat away while pulling your paper off. Don’t bend the mat to much as you can fold the mat and break it.
Yes it’s always better to use an old mat and if you don’t have one make the blue mat less sticky by sticking it to your clothes :sweat_smile: and then after it gets non sticky you can place the paper or cardstock with painters tape check out my tutorial I spoke about it :blush:
The admin @Elena already noticed and hopefully can work this problem soon
If you just keep on using your mats adhesive will eventually come off😊
