Update problems
I have updated the app and its stopped cutting properly. Ive tried the following:
Closing the app and turning the machine off and back on again.
Changing the blade.
Slowing the speed
reducing the cutting force.
Its just munching the card.
Any help appreciated
Maybe the @admin @admins can help with the concern here. Thank you :smiling_face_with_three_hearts:
Have you tried cleaning your blade? I use a scrutched up ball of aluminum foil. You poke the blade in it a couple times by pushing down the plunger part of your blade housing. While you have your blade out check that it is OK an not damaged.
What is your material? Which material’s cutting parameters did you select in the software?
I had a similar problem today but it was that my mat had residue from the previous cut and the blade wasn’t moving smoothly because of that. Is you mat clean? I know it sounds silly, but the little fuzz from the paper can add up after long cutting projects.
How about changung blades? Already happened to me i just change my blade.
maybe you can try changing blades cricut and siser brands are both compatible with loklik
Did you find the problem?
