I made these cute heart earrings using glitter HTV!! The inspiration came from my niece wanting some sparkly earrings ![]()
I used HTVRONT glitter HTV to make them
Supplies for 1 pair of earrings
-glitter HTV I used HTVRONT
-Design software
-cutting machine
-Mini heat press
- Press mat
- teflon sheet
- Jewelry pliers (2 pair)
- 2 jump rings
- 2 Earring hooks
- weeding tool
- brayer
- scissors
Design:
Using the design software of your choice create your design.
I used a heart shape and a circle shape and the slice feature to create my design. I also mirrored the design before cutting
Prepare material:
Set mini heat press to level 2
Cut 2 rectangles of HTV slightly larger than your design (use scissors)
Put the 2 “back/not shiny” sides together
Cover with teflon sheet and press glitter HTV together
Use light pressure for 8 - 10 seconds
Cut out design:
Use a brayer when placing Glitter HTV on mat.
Before cutting, remove the carrier sheet on the side facing up
Cut using a cutting machine
**Adjust the pressure to account for double layer of material
Weed and remove the remaining carrier sheet after cutting
Finishing touches:
Open jump ring using pliers
Place heart and earring hook in ring
Close jump ring
Repeat for other heart
** Earring tip - to keep your earrings facing the correct direction, turn the loop on the earring hook 90° or facing forward. Use 2 pair of jewelry pliers to do this by holding hook in one pair and then turn loop gently with the other.**
These earrings are super light and very cute.
