Hello Community! ![]()
New to crafting? With so many materials out there, it’s not always clear which one to use—or how.
This series breaks down popular DIY materials: what they do, how to use them, and what to watch out for.
Today we’re looking at two for printing on fabric:
Heat Transfer Paper and DTF Transfers
Heat Transfer Paper
Heat transfer paper is specially made for cotton or cotton-blend fabrics. It works best on garments with at least 60% cotton content and can be used on both light and dark fabrics.
Features
Designed for most inkjet printers
Easy to use: print → cut → press
Stretchy and durable—holds up to repeated washing without fading or peeling
Things to keep in mind
- Don’t wear or wash the finished garment for 48 hours
- Always follow press settings for best results
How to use
- Print your design (no mirroring) on the blank side of the transfer paper
- Cut by hand or with a cutting machine; peel away your design
- Press with the design side up, cover with parchment paper; press at 155–165°C for 15–20 seconds
- Finish by removing the parchment or heat-resistant sheet
DTF Transfers
DTF (Direct to Film) transfer is a printing method where designs are first printed onto a special film, coated with adhesive powder, and then heat pressed onto fabric. It’s great for full-color, vibrant prints with lots of detail.
Features
Great for full-color designs with clear layers
Quick process, fewer production steps
Wash-resistant and UV-resistant with good durability
- DTF prints have a slightly raised, rubbery feel—less breathable, so not ideal for large solid prints
- Always test print samples before bulk production
How to use
- Load DTF film into the DTF printer with the printable side facing up
- Design & mirror your image on the computer
- Print the mirrored image onto the DTF film
- Apply hot-melt adhesive powder evenly
- Cure the powdered film in an oven at 266℉ / 130℃ for 120 seconds, until the powder melts
- Press the design onto fabric at 302℉ / 150℃ to 320℉ / 160℃ for 15 seconds, then peel the film after cooling.
Next up: Sublimation Blanks & Sublimation HTV—how sublimation printing works and where it shines.
Missed earlier posts? Catch up here:
Know Your Materials #1 | Adhesive Vinyl & Printable Sticker Paper
Know Your Materials #2 | Heat Transfer Vinyl & Cardstock
