Hi Community, I purchased the HTVRont AutoTumbler Heat Press. I’m using LOKLIK for designs. I’m not so sure on canvas size to use for the 11oz mug? Is there possible a guide someone might have.
Hi @Doyli_Izaguirre! Please check this guide from @BellethehowtoGuru below:
is there also a guide for the glass tumblers and steel tumblers?
What kind of guide are you looking for—print sizing for glass and stainless-steel tumblers? If so, the best approach is to measure your own tumbler’s circumference and height to get the ideal dimensions for your design (Keep in mind: not all tumblers are sized the same—different brands often have slightly different measurements).
If you’re looking for heat press settings, I’ve got a great resource for you right here: HTVRont Auto Tumbler Heat Press - #2 by Jodie
Hello dear the width should be between 20.8 to 21.3 cm no more than that or you’ll have fading results.
I’ve just discussed this with other friend.
I strongly recommend grabbing a tape measure and measuring your object as not all tumblers and mugs are built the same. They may say 11 oz or skinny tumbler but often different brands are different diameters.
After you have your size of the tumbler or mug you want to use, to help size your pictures to fit you can create a rectangle in LOKLiK Idea Studio and size your image on that. Then just hide the rectangle before you go to print it. If you want me to demo this let me know and I’ll create a video for you
If it’s not to much of a bother can you create a video for me?
Totally can, I’ll get on it right now
