👉 IdeaStudio & LOKLiK App Update Log | Issue #3
Thanks for the update @OliviaZzz.
I’ve been working with the app for the last few days, so I’ll have to close it and try the new version later tonight. :sparkling_heart:
Great updates! Looking forward to an upgrade that allows us to use multiple iCrafts at one time, busy season is upon us so we are cranking out projects.
Print then Cut function is not accurate. Since I upgraded to V7, it no longer worked well. I did the calibration using the new sheet and offset values were within 2 and -2 but it made the print the cut accuracy worse! I am glad about the software improvements but please fix first the accuracy with the print then cut function! This is one of the core function that must be close to perfection.
Welcome to our wonderful community @jdcre8s.
There’s a fantastic new interactive tutorial to get you started on your journey, with the chance to win a HTVRont machine.
The new shapes are a great addition. :heart_eyes:
Thanks for the welcome but I would be more grateful if there will be an update asap with the print then cut accuracy for v7 as it is not going any well.
How does your calibration sheet look? I made a post that may help you with calibrating print then cut using v7. You can see it here Calibrating Print then Cut after V7 - #4 by BellethehowtoGuru
I can’t help with that one I’m afraid, as I haven’t tried print and cut - yet.
Hopefully @BellethehowtoGuru’s advice will help.
Thank you! I did the same exact process before and even use the same shape which is circle to easily check accuracy. My calibration values were between 1 to -2 on all sides but still not accurate when I did the print then cut. Probably I would have to recalibrate and try again. But I really appreciate the detailed instruction and the fast response! Thank you very much!
No worries. Let me know if you need any further assistance. Hopefully it calibrates this time for you
Happy Holidays @BellethehowtoGuru! You are a helpful quick responder! Thank you and all the moderators in our community. Your continued sevice to all of us is greatly appreciated. Congratulations again on over 1 year anniversary at this. Your hard work does not go unnoticed! Happy crafting everyone! :clap:t2: :clap:t2: :hugs:
Welcome and thank you for joining :blush:
Oh thank you so much for your kind words :smiling_face_with_three_hearts: made my day :smiling_face_with_three_hearts:
